Air in Front Forks
27 Reactions
Steve Ives
(@none)
Hay guys an gals. I am not sure if i have air in my forks or not so i want to replace the schroder valves as a start. I can  use a small bicycle pump that puts in a couple of pounds for each pump. Is the schroder valve off the shelf or is it something different? 1995 GL1500SE
Sometimes there is a reading sometimes not
Walk with Joy
Steve Ives
Posted : June 14, 2024 5:20 pm
Steve, that Schroeder valve is off the shelf.... standard issue Schroeder valve.
Posted : June 14, 2024 5:49 pm
sheath and Steve Ives reacted
Steve Ives
(@none)
Thanks Miles be safe =)
Walk with Joy
Steve Ives
Posted : June 14, 2024 7:22 pm
Quick_Cal
(@calvin-watson)
Better check the recommended psi in those forks. I think it is very low. If you put in too much air you can blow the seals.
Posted : June 14, 2024 9:34 pm
Given what I experienced when I brought my air pump over, I would get one with the flexible pigtail to get it attached.  Also, learn to release the pump quickly otherwise all the air you just put in will be allowed to leak out again.  AMHIK
Posted : June 14, 2024 10:35 pm
Steve Ives
(@none)
@thane-lewis This is why i bought a cycle hand pump. You just screw it on to the valve and every pump by hand puts in 2 psi. So its easy to control and takes up no space.
For those interested  https://www.amazon.com/dp/B019V1PW92?ref=ppx_yo2ov_dt_b_product_details&th=1
Walk with Joy
Steve Ives
Posted : June 15, 2024 12:16 am
Steve Ives
(@none)
@calvin-watson  Cal Its 6psi
Walk with Joy
Steve Ives
Posted : June 15, 2024 12:17 am
Technically.... it's Pi in each fork leg
3.14159 psi in the Left fork leg, and 3.14159 psi in the Right fork leg .
If you remove the hose joining the two fork legs together, you can get fairly precise psi in each leg
But Mother Honda had hired some former employee from H-D, and in attempting to make their job on the assembly line easier, they suggested adding the air hose to connect Left fork leg to Right fork leg.
And, given that same former H-D employee couldn't comprehend what the numbers to the right of the decimal point meant, he just rounded it all down to an even 6 psi used for the combination of both fork legs.
If only Mother Honda had hired a physicist to put air in those fork legs, we would still be enjoying Pi today.
Posted : June 15, 2024 6:06 am
Steve Ives
(@none)
Miles i stand corrected with a smile =)
Walk with Joy
Steve Ives
Posted : June 15, 2024 6:18 am
Steve Ives
(@none)
New valves fitted and left fork 3.7. Unable to get a pressure reading on the right fork, so for the moment i used the same number of pumps and called it good. No sign of leaky forks so i will remove the right valve again and have a look with a torch for debris. i noted that the round cap that acts as a cover over the valve actually had a piece of another valve cap stuck in the hole. This i was able to prize out and screw the cap back on, and yes i can try a few more valves if need be =)
Walk with Joy
Steve Ives
Posted : June 16, 2024 10:10 pm
Steve Ives
(@none)
Its safe to say that air in the front forks makes a difference when riding. Job done
Walk with Joy
Steve Ives
Posted : June 18, 2024 7:49 pm
