06 TLE (how do I fl...
06 TLE (how do I flush the brake clyinder)
I have the mighty vac connected to the TLE brake cylinder and when I open the bleeder I get nothing?
Any ideas what I'm doing wrong or tips? I do have the sidecar manual but it really does not cover it.
TIA,
John
Posted : July 21, 2009 8:28 am
(@timo482)
ive had no problems bleeding my brakes - is the cover off the res up front?
Posted : July 21, 2009 10:54 am
Yup,
Ended up having to pump the brakes which worked.
Posted : July 21, 2009 12:29 pm
One offbeat question? If I just stop the rig with my front brakes only it pulls a little, is that normal? I do not remember if it did or not before I flushed the system?
If I just use the rear brakes it pulles the other way a bit? That normal? Perhaps I have some air?
Posted : July 21, 2009 12:41 pm
I'm riding an 87 FLHTC with and 87 TLE. If I am slowing and need to curve to the left I use the front brake, curve to the right I use the rear brake, stop straight and I use them both. It took me a while to get used to it, but if you think about how the brakes are set up and where the weight is distributed it makes sense.
Tom
Posted : July 23, 2009 12:21 pm
Yup exactly, as soon as I started using the brakes normally everything was fine......
Posted : July 23, 2009 12:32 pm
Not exactly the best practice according to the book but if it works for you, so be it.
Posted : July 23, 2009 2:05 pm
You know it was normal, as I asked a few others, if you just use your front brake it will pull a little to the left, if you just use the rear brakes it pulls a little to the right. Use both as the book says and the bike stops dead straight.
I went over everything and there was zero air in the lines and everyting is working.....
Thank you!
John
Posted : July 23, 2009 4:17 pm
If "Speedbleeders" were installed that's is extactly what would happen, you have to pump the lever to get the fluid out, there's a check valve in the speedbleeder unit.
Posted : July 23, 2009 6:45 pm
