lower mounts for sputnik
I am looking for both lower mounts that can be used on a sputnik frame. Anybody..??
As we were the importer on these, we still have some replacement items. The lower stock mounts which clamp over 30mm balls run $15 each. We also make our own to work with our mounting systems. These have a lot more adjustment. To run our lower mounts you need two bosses at $65 each, two clamps at $65 each and two hiem joints at $40 each. These are needed to work with our bike specific NOT universal mounting kits. We do not have much left in stock as to replacement parts. We have brake parts, some rubber and one front end sheet metal section the part that is hinged. You can still get windshields from www.bikescreen.com
- 93.6 K Posts
- 7 Online
- 5,630 Members
