Sidecarist needs HE...
Sidecarist needs HELP
10 Users
123 Reactions
Steve, if the  part # on that  alternator is 31100-MT2-015 that is a Hitachi alternator,  and is the  original  alternator.
The brushes part # is 31100-MN5-005, and if that is all that is  wrong, or worn down,  they can be  purchased  separately.
Posted : May 26, 2024 4:01 pm
sheath reacted
Steve Ives
(@none)
Hay Miles
Thanks. The only number i see isAM19H3HV9 nothing else.
Walk with Joy
Steve Ives
Posted : May 26, 2024 4:49 pm
sheath reacted
Steve, I  tried  cross referencing that  number  with any known  motorcycle  alternator  on this  planet,  with no luck.
Please....inspect every  nano millimeter  on that  alternator,  and find a different  number.
Posted : May 26, 2024 5:42 pm
Brstr and sheath reacted
Quick_Cal
(@calvin-watson)
Here's is the label that gives a different number. But it does cross reference to the Honda number that Miles provided.
And here's is some other numbers.
https://store.alternatorparts.com/partno1249401hihitachioelr140-708lr140-708chondaoe31100-mt2-015.aspx
IMG 1234
Posted : May 26, 2024 5:49 pm
Steve Ives
(@none)
Miles the only other number i can find is PT 2019 08 but i suspect that is a date. Nothing else visable
Walk with Joy
Steve Ives
Posted : May 26, 2024 6:11 pm
sheath reacted
Steve Ives
(@none)
@calvin-watson Looks like a good price on that link.
Walk with Joy
Steve Ives
Posted : May 26, 2024 6:34 pm
sheath reacted
Quick_Cal
(@calvin-watson)
Posted by: @none
Actually,,,,, not really. I just linked it to show the cross reference of part numbers. If you search the part number there are cheaper prices for the same thing. Better do your homework,,,lol.
Posted : May 26, 2024 6:39 pm
If that 2019 is a date code, that's not a very happy indicator.  Means that it was replaced relatively early for that model and it's failed again.  I'm not a great "hunter" of electrical gremlins, but I'm willing to bet that some of the wiring in your bike is causing significant current draw while running and that's cooking alternators.
FWIW, we had a Honda PC 800 that sold to a local.  While out on a road trip, the regulator on it went out and instead of under producing voltage, it over produced, upwards of 20v which caused the battery and some connectors to actually melt.  New regulator and rectifier fixed the problem, but it was pretty scary for him when it happened.
Posted : May 26, 2024 10:36 pm
Steve Ives
(@none)
I did look through the history and they had problems with the alternator in 1998 and the brushes were changed then the alternator,. I did strip off some of the crummy wiring and i suppose that could have worked in my favor i am also replacing a suspect relay that is shown in the pictures; i might do a complete relay/fuse change. I did put the volt meter on the battery between the disconnected earth and the battery and it did not show any drain. i could have got lucky and if the alternator is cooking batteries over time 10 years will be plenty right. But investigations will continue.
Walk with Joy
Steve Ives
Posted : May 26, 2024 11:38 pm
Steve Ives
(@none)
Well no parts available locally for rebuild and no part numbers on the case makes me a bit edgy. So i guess its a new OEM from Honda any suggestions on a source for this?
Walk with Joy
Steve Ives
Posted : May 28, 2024 10:04 am
sheath reacted
Steve Ives
(@none)
Pulled the trigger Partzilla, no point in messing around.
FYI Only 0.08 cancer in my system, revisit in 3 months so lets hope it lasts. YEAH ME =)
Walk with Joy
Steve Ives
Posted : May 28, 2024 11:28 am
Brstr, sheath, Ben Franklin and 5 people reacted
(@ben-franklin)
Steve,
I would probably go with the "Shorty" 50 amp kit... Looks like it would fit about where the old one was mounted, without a lot of excess wire or trimming:
https://www.easternbeaver.com/Main/Wiring_Kits/Fuseboxes/PC-8/pc-8.html#30ashorty
Posted : May 28, 2024 12:23 pm
Posted by: @none
Great news on the Cancer front.  We will keep our paws crossed that number continues to drop. 👍
Posted : May 29, 2024 9:41 am
(@sidecarwilliam)
Changing the alt. on a 1500 GW is no big deal and can be done on the side of the road or in your garage in less than 2 hours. Practice will get that time down!  Alternators are available overnight from Amazon for $89.00 to $400.00. A quick look and I think they are all the same units out of China. The second one was in in about 45 minutes. Lucky for all of us that the sidecar is on the other side basic_smile
bill.
Posted : June 28, 2024 5:15 pm
Page 5 / 5
