sidecar tires
I want to know what are the considerations taken when buying a tire for a sidecar. Do I need to just buy a rear tire and use it on the car. It's a 1996 ultra classic. What are the size considerations and which brands offer the best deal? Any help appreciated. thanks. 😮
Posted : May 14, 2010 9:52 am
If you are using motorcycle tires, since the tire isn't a driving traction tire but is a slave tire with braking abilities the front tire is the one most often used. They are also less expensive than rear tires regardless of MFG.
If the sidecar uses an automotive tire it's even less of a problem. Just find the least expensive tire in your size.
Size consideration would normally tbe he same as the original tire was unless you are attempting to raise or lower the rig. Then it's clearance or appearance.
Posted : May 14, 2010 10:20 am
If you are using motorcycle tires, since the tire isn't a driving traction tire but is a slave tire with braking abilities the front tire is the one most often used. They are also less expensive than rear tires regardless of MFG. A Chen Sheng won't give good mileage.
Size consideration would normally be the same as the original tire was unless you are attempting to raise or lower the rig. Then it's clearance or appearance.
Posted : May 14, 2010 10:23 am
Thanks for the info. I've never put a car tire on a bike. Never gave it a thought. You mention it and several others in the forum. Is there a formula for determining the size of the car tire in comparison to a bike tire? The tire I have on the rig now is a Continental Tour 130/90-16 73H. How do I compare this to a car tire?
Posted : May 14, 2010 10:54 am
Look on the net under tires for tire sizes, specs in regard to profile, dimension, diameter, speed rating, etc.
Posted : May 14, 2010 11:30 am
