Sidecar installer in Arizona ?
Tom,
Look on the main menu of the sidecar.com website, under "Sidecar Library" you will see the top menu item "Map of Sidecar Manufacturers, Dealer, and Installers". If you click on that you will see a Google Map, but that is a static image. If you click on it, it will open in a new tab to a Google Map of all places. From there you can zoom in on Arizona and you will see 3 places listed. Research those to see if they will fit your needs.
Jerry
Webmaster
Jerry
Thank you. I see three. I'll make some calls this week...
Also, Tom, if you call Hannigan, and talk to either Stephanie, or Dave, or Corey, they can tell you the name of the shop in AZ that does installations of their Hannigan sidecars...for them. Might be a good source to use the same shop that Hannigan uses for installations in AZ.
I spoke to Hannigan today and they have no installer in Arizona.
There is a shop in Prescott, AZ. called Dying to Ride. I just learned of it while on a ride through Arizona a couple weeks ago.
I spoke to this fella on Friday and he is definitely a shop that installs Hacks.
- 5,479 Members
