RUSSIAN Sidecar Tir...
RUSSIAN Sidecar Tire
My 2000 Moto Guzzi Quota is tugging a URAL sidecar. As best as I can determine it is fitted with a 4.00 x 19 tube type "Uralshina" [?] tire [Mfgd by Sibur?] The tread pattern appears to be somewhat aggressive. Although the tire has E22 and DOT certifications am I crazy driving this rubber at 75mph?
Posted : July 12, 2012 3:39 pm
The Russian tires (and tubes) are known leak air and made very unbalanced. The latest variety may be better but I doubt they are much better.
A tire failure on the hack is not nearly as bad as one on the bike but I would consider a better made tire if I planned on long runs on the superslab. The aggressive tread patterned tires are best used off-road.
Posted : July 12, 2012 6:00 pm
Spuddy, the Uralshina tires have worked well on thousands of Ural hacks for many years. Russian tubes are a bit porous and no one that I know uses them. The aggressive tread pattern doesn't mean a thing on a hack wheel. The newer Duro tires wear a lot better and the tread pattern is a copy of the old Pirelli universal.
If you have doubts about the Uralshina, I suggest you get a Duro and a quality tube from your friendly local Ural dealer. Heindl in Ohio, Crawford in MI or TriQuest in CA do a lot of mail order Ural stuff.
Al Bond
Ural Guy
Prescott Valley, AZ
Posted : July 13, 2012 6:16 am
 VLAD
(@vlad)
Spuddy - 7/12/2012 8:39 PM
Uralshina means Ural tire in russian.
Posted : July 16, 2012 1:23 pm
