Rear Tire Wear/Repl...
Rear Tire Wear/Replacement?
How far would you let the rear tire wear on your rig before replacing it?
Posted : April 15, 2005 12:16 pm
I change as recomended by the manufacture. Dunlop as an example, says go to new when a Lincoln penny inserted into groove upside-down, tread depth below the top of his head. Most have wear bars.Unfortunately, hacks tend to eat rear tires as you know.....if I'm gonna play,I gotta pay!
Posted : April 22, 2005 3:08 pm
does anybody know of a long wear rear tire without having to go to a car tire?
Larry Reid
Posted : May 9, 2005 5:21 am
The Dunlops are probably one of the hardest tires and as a result give longer wear I use the Elite IIs. 401, 402, and police tires are supposed to wear well. New tread depth is shallower than some tires (like Metzeler) but the tread life is longer.
Posted : May 9, 2005 7:33 am
Well, the one I have on now is showing the steel cord so I guess that is about it for that tire. The tire was a Metzeler Tourance V. 17". But do to other commitments I haven't ordered a new one to replace it or have ridden yet this year.
Posted : May 16, 2005 11:05 am
On our XS1100/Motorvation Formula II rig we have had good results with the Dunlop K491. Also ran this tire on our 78 GL1000/Watsonian Palma with good results. Do no tget the K591!
Claude
Posted : May 16, 2005 2:00 pm
I'm currently getting 6500 - 6800 miles from the Dunlop K491 on the rear of my rig.
I have a 1970 Moto Guzzi Ambassador powered by a 955cc Eldorado motor and a Coupe Royale sidecar. Due to the weight and extreme amount of wind drag with the enclosed car I am running quite a bit more than normal toe-in. I'm sure is reducing tire life but I'm pleased.
Hacksaw
Posted : May 17, 2005 5:23 am
I just ran a Dunlop Police tire the entire length of US 60 (VA to CA) and back on I-40/I-81 for a total of 5599 miles. When I put it on just before I left, it had 10/32" of tread. Got home and it has almost 4/32" of tread. We were fully loaded on a Harley Ultra and fought wind all the way west and some coming back (not to mention the rain, snow and hail). The police tire wears much better than the 402's and has more tread when new too.
Posted : May 17, 2005 11:38 am
Thanks for the response. I was trying to decide if I was going to replace my tire before or after going on the Butterfly Rally. Well I decided to replace the tire before the rally, but it turned out to be a lost cause. While in Globe Az. we were rear ended while stopped at a high school crosswalk. So now in addition to wasting a perfectly good tire I will also need a motorcycle to go with a slightly damaged sidecar. The wife and I are OK, but a our vacation went down the toilet. The rig is in the shop and the insurance company is still trying to decide how they will handle it.
Posted : May 17, 2005 12:25 pm
Sorry to hear of you accident but of course the main thing is that you all are alright. Things will get better
Posted : May 17, 2005 2:16 pm
Originally written by lloydrs on 5/17/2005 4:38 PM
When you say "Police tire" which model are you refering too?
Posted : May 18, 2005 8:16 am
It's a Dunlop D402 PT MT90B16 BW (only comes in blackwall).
Posted : May 18, 2005 11:15 am
Originally written by lloydrs on 5/18/2005 4:15 PM
Thanks. I didn't know the model but was aware of Dunlop Bead-Lock tires for special Police model rims only. I didn't realize they had different tread too.
Posted : May 18, 2005 5:23 pm
Lloydrs, How well does that tire handle? Did you have to special order it from someone? My Drag Spec. dealer has no part # for it.
I am installing the raked tree from Liberty on my Ultra. Hoping for alot better cornering.
Thanks,
Scrubs
Posted : May 19, 2005 6:30 am
Scrubs,
The tire handles very well. I didn't notice any difference between it and the regular tires from Dunlop. The only place I've been able to find them is at a Harley Dealer. If your local dealer services any police bikes, then they should have the tire. I also found that it's cheaper than the regular tire (paid $121.50) plus mounting. By the way, I have it mounted on a standard rim too. The techs grumble a bit when they have to mount one because it's harder to put on.
Regards,
Posted : May 19, 2005 9:16 am
