Newbie - nothing to...
Newbie - nothing to compare to
I've put a little over 5K miles on my first outfit and have a few questions;
Having no previous hack experience I have no point of reference to compare with. I was wondering how much strength / effort is "normal" in driving a hack. Driving my outfit is definitely an upper body work out. I am using a considerable amount of strength and energy when driving.
I feel the alignment is pretty good, but I have nothing to compare it to. Below is a basic summary of how it drives:
* Pulls a little to the right. I have to apply constant pressure to the right side
* At low speed, 10-15mph, I can take my hands off the handle bars and it will go straight for a little bit (contingent on road conditions)
* No wobble
* Tires are wearing evenly
* Doesn't really pull when breaking (unless I'm stopping quickly at higher speeds)
It's a Moto Guzzi 1000SP w/ Watsonian Monza
It's sweet spot is between 60-65mph, but has no problem going 70-80mph (other than needing to exert more strength)
So I guess my question is: Does driving a hack simply require more physical strength and effort, or do I need to play around with the set up to improve performance?
With nothing to compare to, I feel like it drives really well, but I have no idea how good, or bad it could be.
I would like to get as many thoughts and opinions from y'all
I LOVE driving a hack! I'm totally hooked and now fantasize about racing AHRMA and the acquisition of a newer bike and a CSM chair. I met some local folks with a BMW Adventure bike with a CSM chair. I was REALLY impressed with the set up.
Thanks for your time and experience,
A
Posted : September 28, 2010 6:34 am
Add some lean-out from the sidecar to eliminate the pull to the right at speed.
You should have neutral steering at an even speed on a normal roadway if the bike from sidecar leanout is correct.
Don't drive with hands off the bars. A bump could cause a tank slapper.
Even tire wear shows you are not out of alignment as far as toe-in is concern
A pull right when on the throttle and a pull left upon braking is normal for an asymmetrical vehicle.
There will be extra steering effort needed if there is a steering damper and no trail reduction alterations in the front end.
Posted : September 28, 2010 7:28 am
Hack'n - 9/28/2010 12:28 PM
Thanks Lonnie! I'll start tinkering with the leanout next week.
There is a steering dampener, but I have no idea what, if any, alterations to the front end were done by the previous owner. Any tips? What should I be looking for?
* I don't make it a practice to drive with my hands off the bars. Only did it once, and briefly on a little back road to see if it would go straight.
Posted : September 28, 2010 8:04 am
Steering mods would be leading links, leading legs, raked triple trees, or aftermarket trees.
With other than easy steering probaly none of these exist on the bike.
Lonnie.
Posted : September 28, 2010 8:22 am
 PJR
(@PJR)
Welcome aboard. New to sidecars this year myself. Have 5000 or so miles so far this year. I was the same as you, thought effort a little high, but nothing to compare to, so read this board, asked questions. Decided I was going to dedicate bike to being a sidecar rig only and installed 8* triple trees. It is like installing power steering to the rig. I can ride all day and it feels like I was just riding the bike.
By the way, I lived in the Charlotte area for about 8 years. Great riding roads.
Good luck, Paul
Posted : September 30, 2010 12:51 pm
