My '81 CLE Rebuild Finally Done!
After 3yrs it's finally finished. I bought this and the bike in the fall of '11. Both needed re-doing. The seller only had it on the bike once just to try it when he first got it 8yrs before. The bike took the most time and money but the sidecar had it's own issues. the body had a hole punched in on the bottom, broken fiberglass. It had several layers of paint that would be to thick to do again. Then after posting pic's here someone noticed the shackles were added on to (the front mounting bar also), that made the tub sit lower causing the damage. The first pic is how I found it it. Then disassembly.
Looks really good, I was wondering about the inside of the sidecar, did you have carpet glue residue you had to remove? If so, how did you get it off? Thanks, Dave
There was that yellow weather stip glue all over the place from years ago. I just took a corse sanding disk on a orbital sander, 40 and 80 grit and went over it lightly without grinding into the fiberglass. I had new carpet for it, but the older ones didn't have it originally, I decided to not use it. So I just resprayed the interior with a speckle paint and layed some cheap indoor/outdoor carpet for the feet
Looks good. Thanks for the pictures.
The rear sling that attaches to the springs broke on my rig at the left mounting hole. I recommend you reinforce it. I welded some 2 inch long square stock at the holes.
Crilly can you post a pic of it?
- 5,469 Members
