HARLEY DAVIDSON FRO...
HARLEY DAVIDSON FRONT FORKS
My 08 RoadGlide has the front fork lowering kit on it , can I hook up a 08TLE to it or do I have to go back to the stock fork length? Also I have after market rear air shocks with its own compressor will those work also? I know it's lots of questions from the newbe but please bear with me guys. So far you have been great and I have learned so much just reading the threads and I'm ready to do this and become HACKED it looks and sounds like so much fun.Thanks for your help.
Posted : November 14, 2009 10:04 pm
Things will fit with the front end lowered but you sacrifice ground clearance.
My lowered RK rig would scrape a lot over speed bumps if I wasn't careful.
An option would be to upgrade to the trike trees and tubes which come as a package. you'd be killing two birds that way. The ground clearance and the steering difficulty, since these tubes are 2" longer than stock and will level out the bike with the raked trike trees.
Power steering and ground clearance for the price of either. A win, win situation.
The air shocks will be fine.
Posted : November 15, 2009 5:54 am
I have a classic with a TLE on it and lowered the front and rear, no issues with installing, i did find that if i raised the lower frame mount the lean brace then lined up a lot better
Posted : November 15, 2009 12:34 pm
(@timo482)
i installed the liberty trees WITHOUT the spacer - so its lowered one inch in front
i have a 15" car tire on the rear so its lowered 2"
handles great on the freeway - speed bumps - no go - i ride the bike frame at a gap or edge or go around
ps - i get sore wrists - im 6.2 over 300 with small hands - id never run a sidecar without raked trees - the wrist pain is just not worth it. [im also not 22 anymore - when i was 22 i rode all over the mountains without a raked tree]
Posted : November 17, 2009 7:30 am
Lonnie where can I get trike trees and downtubes together?
Posted : November 17, 2009 2:43 pm
These items are only available through Harley dealers on special order.
They are replacement parts for the new TriGlide trikes.
Posted : November 17, 2009 3:44 pm
So the TriGlide trees and down tubes will work on an 08 Roadglide. I thought I would have to go with the Liberty trees or Champion. Is the Triglide set up about a 5 degree rake? Do you have part # for these?
Posted : November 18, 2009 4:12 pm
(@timo482)
the tri glide parts will work
its about the same amount of labor
check the parts price and then decide
Posted : November 19, 2009 5:35 am
