Hack tire...
I just picked up my Rig and find I need a tire for the Sidecar. Currently has a Bridgestone Potenza on it in 165/65/R13. I did a search on here and found nothing about a Sidecar tire. Plenty of Darkside info though..
What's a good replacement for this tire since it has been discontinued? I need to get one soon as it's at the wear bars.. Here's a pic of my Sweety trying the rig on for size..
From the factory this sidecar more then likely had a 155 13 however a 165 will work. This is an automotive tire, any automotive tire store should have no problem helping you.
Like Jay said, originally it was probably a 155/13 tire. I've never tried a 165.
I have used Firestone 745 F-560, size 145R13 24 psi and here is where I found them:
https://www.cokertire.com/145r13-firestone-f560.html $70.00
https://www.cokertire.com/145r13-vredestein-sprint.html $85.00
http://www.summitracing.com/search/part-type/tires/tire-size/145r13/tire-type/passenger-car/wheel-diameter/13-in
The sidecar tire I have on now is a Coker Verdestein Spint, 145R13, from Summit racing. $85.00 plus shipping, total $102.95 The Coker tire was a little more money but I wanted to see if it lasted a little longer. I average about 15,000 miles per tire. Since you indicate the Bridgestone Potenza 165/65/R13 will fit I might try the Bridgestone next time.
If your interested, on the rear of the bike I am running a 195/55R-16 Firestone Precision Touring at 28 psi
Looks like you will need a thin walled socket for this one.
NWSC
Hack'n - 7/5/2016 10:58 AM
NWSC
I will also now need 4 new Lug Nuts....
Here is what happened to the thinnest wall socket I had. 12 Point so it didn't treat the lug nuts well.. Chalk line is where it had to be tapped in with a BFH..
I have a similar wheel. No help getting the lug nuts now, but for future, mine came with much longer chrome lug nuts that stick out far enough to get a wrench on them. Likely can get them at any autoparts store.
RoanokeRider - 7/6/2016 8:43 AM
Thanks for the tip.. I will look for them after I find a tire..
Got those Chrome Lug Nuts today. Sure makes a difference..
Get the chrome acorn type lug nuts, thread is 1/2 inch 20 tpi.
Any tire store should have them.
- 7 Online
- 5,450 Members
