Conundrum of SET UP;
I just went to this post and saw N O T H I N G !!
No wonder no one has responded.
Try again
Road King Classic w Liberty Sidecar. Heim joint connections to bike. Leveled the sidecar after each adjustment.
I have set my rig up to the recommended toe in and lean out told to me by Liberty Sidecar , but I still got pull to the right. I increased the lean out to double what was recommended and still got
pull to the right, I went to 3 times the recommended lean out and still have slight pull to the right. I am getting way over on the lean out. 3/4 inch over the height of the tire what ever that comes to in degrees.
I know that the toe in is not supposed to effect pull right or left much, but it seems to me that increasing that some would make the car steer the rig to the left, decreasing the pull to the right without increasing to even more lean out.
I would love to hear from anyone with the same rig to know what you are running for adjustments to get neutral steering.
well to be honest - i got mine so that it was dead straight on totally flat surface - on the road the road leans right and it pulled right.
so i put on a liberty raked tree - end of problem
in fact it was so good that i cant imagin going back
Cool,
I have the Liberty Raked trees that I bought with the rig and will put them on this winter when I get some time and it is too cold to ride. For now I won't be going far enough to have the right pull really effect me as it isn't great, just a small right bias.
I can't imagine what a raked tree or leading link would have to do with the bike pulling left or right. That's kind of like saying, "the rear tire is bad so I better replace the headlight".
Don't know nothing from nothing but that is essentially what the guy from Liberty said also. Get it close, put on the raked trees and all will be good
For the greatest part, all a raked tree, or leading link for that matter, will do is to make it easier to steer at low speeds. Unless, of course, there is something physically wrong with your existing front forks. Neither design should have anything to do with pulling right or left, stopping in a straight line, or even front end wobble. I have had folks tell me that a wobble was cured by a leading link, but I suspect the original forks had bearing related problems, either at the wheel or at the frame neck.
I remember as a boy working in an automotive parts house. If you came in to buy a starter or alternator you could to return your old one as a rebuildable core. We purchased an alternator load tester and the boss taught me to use it by having me test the core alternators. In an overflowing 55 gallon barrel of alternators, I found two that did not perform to manufacturers specifications. The boss said this is because the first thing you do when you replace an alternator is to disconnect the battery, then before you reconnect it, you clean the clamps and tighten things up. Chances are, cleaning and tightening the clamps was all that was really necessary. We became the first shop in town that would test alternators and starters for free.
Likewise I believe a lot of sidecar issues are resolved by accidental changes that we sometimes don't realize we make.
When I bought the Liberty raked trees for my FLH/TLE rig, I was told they will "mask an inproper set up". Also they do infact cure a wobble. I took off the steering damper as it is no loner needed!
And your bearing preload and torque is all exactly the same? That's surprising. When I was looking at putting one on my Goldwing, each place I talked to emphasized that it would not cure a wobble and might even create one. Since that was the only thing I was trying to cure I never went any farther. Likewise, I see a lot of steering stabilizers on LL bikes.
Yes bearing torque was the same before and after instalation of the raked trees. You might consider giving Liberty a call and ask about how they might work on a Gold Wing. My expeince with the Harley application may not apply.
Kirk is right. After the Liberty trees are installed on a Harley/Harley S/C rig the damper is not needed and the mounting bracket makes a good mount for an auxilliary driving lamp.
Originally written by Hack'n on 10/27/2008 12:49 PM
I stand corrected. The Goldwing/Hitchhiker rig was 5 sidecars ago. I have no need for a leading link or steering stabilizer on my present Guzzi rig.
That is exacly what I did. I mounted a 5" dia light on the damper mount and a second 5" light on the right front leaf sping mount of the chair. Now there is plenty of light spread across the entire rig
- 3 Online
- 5,479 Members
