looking for a compl...
looking for a complete rig
12 Users
 stew
(@stew)
I HAVE AN EASYRIDER WITH EVERYTHING YOU MIGHT NEED TO HOOK IT UP TO ALMOST ANYTHING. ITS BLACK AND IN ROIGINAL CONDITION
Posted : July 8, 2015 9:22 am
(@reidxv)
Hi: Did you ever find a complete rig? I just recently listed mine for sale. Any questions, let me know. I'm in Rhode Island, southern part right off I-95.
Posted : July 20, 2015 10:53 am
(@Frankenzuki)
Thank You to all who replied. Borrowed a Royal Enfield from a guy I used to work with. Has a Cozy Sidecaron it now. I pulled the interior out and have been cruising around with Maya for a couple weeks now. Only had 587 mile on it when I picked it up, just shy of 800 miles on it now. Weve been able to put enough miles on now that I'm comfortable that this will work. Just bought a slightly used Velorex 562 for $800. Will be mounting it up on my 79 GS1000. I'll get that squared away and then give the RE back!
Posted : July 23, 2015 5:53 am
An early 562 will work with an early GL with upgraded suspension and ballast. Remember the 562 Standard was designed for a 500cc bike that weighed a little over 300# and will bottom out and wallow in turns with the OEM suspension. After 2004 the 562 Cruiser models had a beefier suspension. One can upgrade to this for around $700.
I have a Bolt on upgrade for use with heavier bikes or for off-road usage that uses a 1" axle instead of the 15mm stock one.
$300. including US shipping.
nwsidecar@aol.com
Posted : July 23, 2015 2:20 pm
(@Frankenzuki)
Lonnie, Thanks for the heads up. This was previously mounted on a 73 FLH, much bigger than my Suzuki. The PO gave me a couple of ballast weights he had used with the car. I'll get it mounted up and see how it is. I have a set of leading axle forks i'm going to swap onto the bike to help reduce the trail. Anybody have any tire recomendations? 18" rear, 19" front right now.
Posted : July 25, 2015 3:04 pm
(@adamwhite)
http://www.cycletrader.com/listing/2013-Honda-Shadow-AERO-115381205
Here is my current listing for sale.
Posted : August 13, 2015 5:04 am
(@SidecarRob)
If you're still looking, I'm selling my rig: a 2005 Yamaha Royal Star Venture with Hannigan Classic Sidecar
I have a "feeler" posting in the For Sale section of the forum -- Check it out 🙂
I'm in Cherry Hill, NJ so we're about 3-4 hours apart
Let me know if you have any interest or want more info
Thanks!
Posted : August 27, 2015 6:48 am
(@sidecarJIM)
I have a 2013 Burgman hpp scooter with cozy sidecar attached. Recently rode it from Oxford, MD to Groton, CT. 65 MPH all the way. I live in Groton, CT. text me at 860-287-1108 if you are interested.
Posted : August 31, 2015 8:59 am
(@Frankenzuki)
Thanks again to all who replied. I think I'm all set, Still have the Royal Enfield. Painfully slow but a pretty good around town rig. Going thru the Velorex 562 I picked up, removed the body, cleaned / painted the frame. Heeding Lonnie's advice about the GS1000 probably being too big for the 562, I have it mocked up on a 78 GS750. Changed the triple clamps to a set with a bit more offset and am using the later model leading axle fork tubes to decrease the trail. probably won't be finished with the Suzuki until the spring.
She's a little bigger than she was when I started looking.
Posted : September 1, 2015 5:19 am
