Can't add images
22 Reactions
(@jerry-m2)
I notice there is no 'insert image' or attachment button. After reading some support forum posts it is not a basic feature. There is some php code to add to the Wordpress theme that helps but the recommended solution is to purchase a dedicated add-on ($30). I will try to add the code to experiment with it. And I will wait to see before I spend any money on purchasing add-ons.
Jerry
Posted : March 23, 2024 11:23 am
(@webmaster)
Honorable Member Admin
This is a reply. See my next post ('test attachments') for a better explanation of how to edit and insert images.
Jerry
Posted : March 23, 2024 9:48 pm
(@webmaster)
I just purchased and installed the "Advanced Attachments" plugin for the forum software. Here is a description:
"wpForo Advanced Attachments addon is a full-fledged file uploading, attaching, displaying and managing solution for wpForo. It comes with super interactive, multi functional file attachment features. Allows to attach multiple files, images, videos, audio and all other file types you’ve allowed in settings. Files can be inserted inline, between post content texts. It opens a nice lightbox slider with many features to view and watch different type of attached files. This addon keeps user specific attachments in separate media library and allows users to use the same file on different topics and posts. You can limit file types, max uploaded file size and do a quick translation of front-end phrases using addon settings."
So here is a test.
logo USCA United Sidecar Pin 293x250
Ok, that worked. But it is a little tricky. You have to select the little checkbox on the right first, then select the action you want to take ("Add to post" or "Insert into post").
Cold biker
Here is another one.
2022 Joyce Canfield Rally 22
Takes a little getting used to. Also the thumbnails seem small. After submitting the post the thumbnails presented are larger. And it has a nice "lightbox" effect when you click on the pics. This is a great improvement over the stock behavior.
Jerry
Posted : March 25, 2024 3:25 pm
Thane Lewis reacted
I'm gonna create a post with an inline image hotlinked via URL, and also with one uploaded from my laptop.
I recently bought 3 feet of threaded rod from McMaster-Carr.  It looked like this ---->
😩 OK, I can't find any checkbox on the right to click on.  I also don't see any "Insert Image" button or anything similar in the toolbar.
Also, below this window where I'm composing this post there is a message that says "No more attachments are allowed today."
Try again tomorrow maybe?
Posted : March 26, 2024 12:20 am
(@webmaster)
Well THAT's certainly curious! Investigating...
[Edit] Ok, down below the editing window is an icon and a link that say "My Media" and also a paperclip icon with "Attach Files". Click on either of those to insert the respective media types. I will try here:
Group ride 800x600
Seems to work for me. Look in your profile and see if there is some indicator of your status.
Jerry
Posted : March 26, 2024 8:48 am
I don't have a "My Media" and no paperclip.  I'm gonna post this reply, then go and turn off all my adblockers to see if that fixes it.
Posted : March 26, 2024 7:17 pm
I didn't have to turn off my adblockers!  As soon as I posted the above post the My Media tool and the Attach Files tool appeared below this window I'm typing in now.
OK, so here's a hotlinked image --->
😩 still no way to hotlink
So instead I saved the image to my hard drive, then uploaded it using My Media, then I'm gonna add it using the Insert tool  ---->
threaded rod
So that works OK.
Posted : March 26, 2024 7:25 pm
(@webmaster)
This is pretty cool - you can paste screenshots directly into your posts! Without having to save them to a file!
I am running Windows 11 on a desktop PC. To take a screenshot you press Windows key, shift, S - then drag to highlight the area to copy. Then I can go and press control V to paste the clipboard image directly into my post! Automatically gives it a filename. Nice!
Jerry
Posted : March 26, 2024 8:00 pm
(@smitty901)
My other toy test . Posted using Paste worked just fine.
20230920 170740
Posted : March 27, 2024 7:53 am
(@smitty901)
Test attach file Sidecar file PDF loaded opened with Open in new tab
20230920 170740
Posted : March 27, 2024 8:05 am
I have a message below the text box that says "no more attachments are allowed today".
Posted : March 27, 2024 8:16 am
Screenshot 2024 01 16 at 12.18.09 PM
I put this in by dragging it onto the edit window.  Still not seeing anywhere Jerry is describing for attaching files.
Posted : March 27, 2024 8:21 am
(@smitty901)
  In my second post I do not know why it posted the tractor picture a second time . It should have only posted the Sidecar PDF file.
Also was not able to delete the picture by editing.  I will trace my steps and see if it was my mistake.
Posted : March 27, 2024 8:22 am
Also, looks like each page is five replies.  That makes for a lot of page movement.  Can the post per page be set to 10 or more?
(@smitty901)
@thane-lewis
This should  show it. You may need to log out and back in or refresh
Posted : March 27, 2024 8:24 am
Page 1 / 4
