Ural sidecar swinga...
Ural sidecar swingarm bushing deflection problem
When rolling the rig around the shop at work yesterday I heard some creaking noises and decided to investigate them. I found that when rolling the rig back and forth with in an arc the sidecar swingarm bushings deflect a lot, with a load in the sidcar that gets the swingarm off the bump stop the end of the swingarm will pivot about 3/4-1" inboard of where it should be. Has anyone else had this problem? When I put the swingarm on I noticed that the bushings don't protrude out of the swingarm any and therefore don't get sandwiched between the mounting ears at all. Maybe I have the wrong bushings? They are brand new, but they don't seem to fill up the space very well. Any help would really be appreciated.
Posted : May 16, 2008 8:54 am
The Velorex has ball bearings that lasts much better then bushings.
Just a thought
Posted : May 16, 2008 11:05 am
That'd be nice, to bad the Ruskies didn't do that. I'm going to take some pictures of it tomorrow, I think. It may be normal, I don't know. It always defaults back to straight, it just tweaks in corners.
Posted : May 16, 2008 8:30 pm
(@Ivan-Rider)
Originally written by Ckretintimidator on 5/17/2008 1:30 AM
The 2008 Ural now has bearings in the swing arms.
Posted : August 16, 2008 7:32 pm
