Sidecar Disc Brake
My sidecar has a separate brake peddle mounted beside my running board peddle. I'm thinking about changing it over to putting in a tee and quick disconnect to the rear and sidecar brake so they work as one. Its on my 2003 Kawasaki Vulcan Classic and I was wondering where is best place to get the line. tee, and quick disconnect to fit it?
If Motovation can not help you with this we can.
Thanks, What would I need and cost?
Not sure, I would need to know more about your brake line. What we do is a double banjo bolt to hook up the brake, these run $19.95 however chances are you are going to need a different brake line to make this work which we can supply but can not quote until I know more about lengths and fittings.
Ok thanks, let me see what I can do.
- 3 Online
- 5,482 Members
