Relocate Battery to...
Relocate Battery to sidecar BMW K1100 LT / Calif car
(@Peelot)
I am planing on moving the Battery location from the factory case on my K1100LT to my Calif. sidecar. Have made a bolted down battery bracket for
the rear of the car behind the pas. seat.
What gauge battery wire is recommended to connect the battery to the motorcycle? I plan on using an high quality jet ski battery. Haven't measured the length
of wire required as the bike and car are separated for other maintenance. Guessing it would take 5 -6 ft. of wire. I plan to connect the pos. wire to the bike
thru a marine battery switch.
Thanks for your help.
Posted : February 14, 2014 2:29 am
(@draperg1)
Was planning on doing the same on my current rig, but after some figuring decided to locate between chair and bike. I was going to need 6 1/2 feet of GA2 cable with a cut off. Did not want to reset my electrics every time. Decided to go with about 2ft of GA4 cable and no cut off. Each to his own! Good luck!
Posted : February 14, 2014 3:30 am
