Rear shocks for HD ...
Rear shocks for HD sportster
(@Sean-Hogan)
Hi all,
Can any one tell me if they have upgraded the rear shocks to cope with sidecar work? I have an 06 HD Sportster custom 1200, it can sometimes wallow into left handers, remember we drive on the left side of the road in Australia so the sidecar is mounted on the left. It can sometimes bottom out as well, I have a LL front end with Koni shocks and the sidecar also has a Koni shock. The bike has the standard HD shocks I run them on the second highest spring tension, I find the highest setting delivers too harsh a ride. Otherwise it's a great handling outfit.
Any advise welcome.
Sean.
Posted : June 15, 2013 5:07 pm
(@sidewise)
I don't have a sidecar on my sporty that's my solo machine but I can tell you stock HD Sportster shocks come with only two adjusments, too soft and too firm. Set at softer setting they are extremely hard to get to that initial one inch compression and then totally collapse with load or aggressive riding set at firmer setting might as wheel be riding a hardtail. Any of the after market shocks perform better.
Posted : June 16, 2013 4:41 am
Sean Hogan - 6/15/2013 10:07 PM
... Can any one tell me if they have upgraded the rear shocks to cope with sidecar work? ... The bike has the standard HD shocks I run them on the second highest spring tension, I find the highest setting delivers too harsh a ride. Otherwise it's a great handling outfit.
Sean, I too run my rear stock HD shocks on the 2nd highest setting and it's OK at best. I suggest checking on Ikon shocks from down under. We have suspended Jena's Burgman both front & back with Ikon fork springs/shocks -- she's well pleased with the results.
Posted : June 16, 2013 4:46 am
(@Frankcanuck)
I would go on ebay and get me pair of road king air shocks....they work great and not expensive.
Posted : June 16, 2013 2:49 pm
I use the rk air shocks on mine work great
Posted : June 17, 2013 1:26 am
