pull left & right
I had considerable wobble up to 30 mph on my rig and tried everything within reason. Then I decided to change the head bearings to tapered-roller type.
NO MORE WOBBLE. It was a total cure.
Posted : September 26, 2007 4:51 am
Overtime,
Why it was a total cure?>>!!
You had nests in the old bearing and the force to get back to the nest was like a wack > a hit backwards form one side to the other. An obvious tapered bearings last a whole bunch more load then the tiny balls that rest on only a small spot.
Best regards
Sven Peter Pan
Posted : September 26, 2007 7:44 am
