New solution for an...
New solution for an old problem.
My Valkyrie has always had a minimal shimmy in the front end on deceleration. Nothing terrible, but it was there.
Most sidecar rigs exhibit this problem, which is why many have steering stabilizers.
When I pulled off the Dnepr and installed an almost identical Ural car, the shimmy got much worse, not only at low speeds but at any speed decelerating. Anytime I let off the throttle it would start. I check head bearings, tire pressure, alignment, load balance, and everything else that has been known to cause this all to no avail.
Yesterday, unrelated to the shimmy, I changed front tires, from a Dunlop D206 Radial to a D404 Bias Ply. My shimmy is gone! 100% gone. Today I was able to decelerate from 70mph to stand still with very light pressure on the handlebar and NO SHIMMY AT ANY SPEED.
Before you say the tire was the problem, I should point out that the tire I removed was installed after the shimmy started and wore out at about the same rate as every other tire has since I bought the bike. Unless the last two tires were both bad, I installed each the same, cleaned, inspected, packed, torqued, and preloaded the bearings, etc. etc.
I guess what I'm saying is, Don't give up! There's a solution to every problem if you just keep plugging away.
Posted : August 12, 2006 4:19 pm
Huh... I only get a tiny bit of shimmy when excelerating. If I install your tire with the rotation backwards, do you think it would cure MY problem?
Posted : August 12, 2006 4:59 pm
Maybe! But you might have to do it on the First Monday after the first Saturday of last month for it to work. :0)
One never knows, do one?
Posted : August 12, 2006 5:26 pm
(@Mark-in-Idaho)
Was the previous tire balanced? I've noticed a slight increase in my shimmy since the tape one tire weights disapeared.
No, I do not yet have a steering damper, I just keep both hands on the bars between 15 and 25 mph. No problem after that.
Posted : August 13, 2006 7:29 am
Radial tires seem to have more sidewall flex then bias ply tires.
I suppose it is because the tread area is bound by the belts so it won't flex. That may be part of the cause.
Notice how the radial tires on a four wheeled vehicle bulge above the tire footprint. Some have a tendency to squirm. My brides new Honda Accord radials will squirm on some deeply grooved pavement.
Posted : August 13, 2006 8:09 am
Originally written by Mark in Idaho on 8/13/2006 10:29 AM
Yes, All three tires, both 206's and the 404 were balanced on the same balancer.
Posted : August 13, 2006 8:58 am
Hi Mike..methinks ye war infested with the dreaded "mystery shake" syndrome best cured by a visit from ghostbusters. Actually, even my rig with the UNITFORK setup w/damper shakes slightly upon deceleration. Really only noticeable with empty sidecar...go figure
Posted : August 13, 2006 1:25 pm
