Metal warping/oil c...
Metal warping/oil canning
 DeeW
(@DeeW)
I am building an HD vintage style car. I approached the build the wrong way. I plug welded a 1/2" angle around the perimeter of the inside of both side pieces so I could plug weld the top pieces. Well using 1/8" angle and plug welding 18 ga. body panels ended up warping the side pieces. My question is how are the sides and top pieces attached to each other. I think the angle idea is all wrong.
Posted : April 1, 2018 7:34 am
(@George-Ryals)
DeeW, you are obviously putting too much heat into too large of an area at one time. What welding equipment are you using? With a TIG or MIG welder you should be able to tack weld the edges together with tacks one inch apart until you get the whole thing together. Then put a tack between those tacks and so on until there is no room for any more tacks....and you are done. grind smooth and tack any flaws.
Posted : May 11, 2018 8:12 am
