Liberty triple tree installation
I am presently installing these triple trees on my 09 Electraglide. First problem, no install instructions. Second, slop in new trees. If I tightened enough to get the slop out, top of lower tree rubbed on neck. I ended up shimming with a washer under lower bearing dust plate in order to get proper fit. In doing this I found fairing braket hole alignment was off due to the shim. It is slight enough I feel can enlarge the holes to get proper alignment. Third problem, no left right turn stops on the new trees.
Any suggestions or comments from others who have done the install?
Also you can reach me at 985-373-4686
Posted : October 8, 2013 3:55 am
- 3 Online
- 5,474 Members
Our newest member: oleen3
Latest Post: Steering Damper
