leveling sidecar fr...
leveling sidecar frame questions (new to sidecars)
(@lowriderbud)
Jeff Online, I believe your suggestion to invert the bottom rear mount is what I need to do to get enough adjustment to compensate for the bike being so much lower than the sidecar frame. I am going to try that, and I will most likely need to rebuild the lower front mount and weld some of the clamps in place so I can have the desired alignment between bike and sidecar.
Thanks to saophoto also for following up with the changes he made; looks like they might help with the realign.
I'll post when I get to a place that I feel is in the right direction. I'll also post if I screwed things up...
Later, Bud...
Posted : November 6, 2017 12:09 pm
(@saophoto)
Hi Lowrider!
I have my rear bottom inverted as well, it angles up a little to the bike frame but so far is holding great.
If I didn't invert it on mine the strut would be too close to the heel of my boot and I didnt want to chance snagging on it when I need to hit the brake.
Posted : November 6, 2017 1:07 pm
