help with changing ...
help with changing rear tire with sidecar attatched?
would like details if this is possible and any info on the help
am new to sidecar maintenance
thanks
rjwitch
Posted : April 26, 2008 10:20 am
Put a jack under the rear of the bike and change like you would normally. You have the sidecar to keep it upright.
Posted : April 26, 2008 10:32 am
Originally written by thekid on 4/26/2008 1:32 PM
Right, you can even use a car style floor jack now. Just let it pivot up on the front tire and sidecar tire.
Posted : April 26, 2008 10:42 am
The above solutions apply unless you have a free leaner sidecar.
If so the bike can be hoisted from above to get the clearance to remove the rear tire.
Posted : April 26, 2008 11:57 am
(@gnm109)
I use a floor jack and a sheet of 1/2" plywood. Lift the rear wheel up about 6" and go at it. The bike will balance on the front and sidecar wheels.
Posted : April 26, 2008 1:14 pm
thanks to everyone who responded. I am new to a sidecar and need loads of help. Another question can I adjust the valves on a Valkyrie with the sidecar attached also?
thanks
rjwitch
Posted : April 27, 2008 3:55 am
Originally written by rjwitch on 4/27/2008 6:55 AM
thanks
rjwitch
That depends on your mounting. I had no problem doing so on mine, but I like the car out away from the bike. I knew a guy with a Valkyrie Interstate that had the car pulled in close so he could easily fly the chair. He complained that he had to drop the car to adjust his.
Posted : April 27, 2008 6:18 am
