Car wheels on URAL
I would like to mount carwheels on my URAL now the rear wheel is in the center when i will mount a carwheel from 6" or 7" the wheel is out off the center does that mather.
I think when the rear wheel is out off center to the left side (from behind view) it wil ride better.
Thanks in front.
Posted : November 14, 2004 8:37 am
If you have a right side mounted car, having the wheel rim and tire set more to the left would cause less strain on the axle. Since you have a cantilevered axle (unless it has been modified), having the weight and load concentrated closer to the swing-arm will reduce the shear forces and torsional forces on the axle and swing-arm. This will reduce the tendency to bend the axle or twist the swing-arm even though the wheel/tire assembly may be heavier than the original one.
Posted : November 14, 2004 8:52 am
So if i understand it good it's better out off center when the sidecar is on the right the wheel mounted to the left.
Posted : November 14, 2004 9:00 am
