Car wheel info...
Hello to all, I'am new to the forum and have just installed my first sidecar. I have a 94 Road King and have just put an 03 Ultra car on it
and would like to put a matching wheel on the car. I have the stock mags
on the bike and the car has an 03 mag with a disc brake on it.
Are the car wheels interchangable with the bike wheels? I want to keep
the disc brake and was hoping to pick up a stock wheel and make the swap.
I'am having way too much fun ridding it to take the time to pull it apart
and compare the bolt patterns and dimentions. Thanks for any input.
Posted : September 21, 2007 3:21 am
(@timo482)
a front wheel of a single brake touring softail is the same wheel. - the disk brake holes are the same - its the other side and the bearing dia that change.
the tournig wheels are not the same.
exactly what pattern wheel do you have? exactly what pattern wheel do you want?
Posted : September 21, 2007 6:51 am
"exactly what pattern wheel do you have? exactly what pattern wheel do you want?"
I have the stock mags on the bike and I would like to match them.
I'll pick up a softail front mag wheel from the 90's, they look the same
as my 94rk. Thanks for the info! Rusty
Posted : September 22, 2007 1:46 am
Are you asking if the wheels from a 94 bike will fit an 03 car? I'd check the axles as well. Harley is known to change the axles just to make the aftermarket wheels no longer fit. For instance, in 07 they went from a 3/4" axle to a 25mm axle. I believe in 94 they were using an 1" axle. The 03 wheels would need the 3/4" axle. The bearings are different as well.
Posted : September 24, 2007 3:14 pm
