Another Tire Questi...
Another Tire Question?
When I purchased my 81 Goldwing 1100 I, it came with Avon tires on it, with miles left on the treads. As all tires do and I'm told that with a sidecar attached, they ware more rapidly than without the sidecar.
My question is this: Will it be necessary to adjust the Lean, Camber, etc... if I should buy different tires? The wheels remain the same, only the tread width, design, and of course, different brand of tires, will be different.
Posted : April 29, 2007 6:54 am
(@Mark-in-Idaho)
Any time I change anything on my rig, I recheck the sidecar alignment, including new tires. I've made up some semi permanent angle iron rail for this purpose. It only takes about ten minutes to set up and measure.
Posted : April 29, 2007 9:49 am
