Adjustable Lendgend...
Adjustable LendgendAir System Harley
Hey everyone, just bought a California Freindship II, want to mount it on a 98 Harley Heritage that has the LendgendAir adjustable shocks. The front has been lowered one inch, any problems?? Also how do you tell what year the sidecar is, I contacted CaliforniaSidecar with the ser# and they said they can not track it that way,,, any help. thanks Axe
Posted : August 12, 2004 3:39 am
The Heritage already has limited ground clearance as stock. If your mounting system has any components that hang below the frame you may have a scraping problem with steep driveways, speed bumps and trailer ramps if used. A good example is the Softtail California (Harley Clone) framed Indians. With a Legend sidecar the front mount only had a couple of inches ground clearance. I'd suggest raising it back up for the hack.
If your sidecar has a trailing link, coil over shock suspension and uses 5/8"x5/8" heim joints for the two lower mounts you are in good shape chassis wise. If not it will need safety upgrades. Like a vintage sportscar, with a hack the year isn't as nearly as important as the condition of the unit.
Lonnie Cook
Northwest Sidecar
nwsidecar@aol.com
Posted : August 12, 2004 6:42 am
Hey Lonnie, I'm taking the bucket off for painting, if I shoot you a pic of the frame can you tell me if I need the up grade and do you carry it? thanks Greg B
Posted : August 13, 2004 3:27 am
Greg,
Shoot a couple, let's see what you have.
Posted : August 13, 2004 10:10 am
Hey Lonnie, I'm in the prosess of moving, as soon as I get my e-mail on line I'll send some pics..thanks Greg b (Axe)
Posted : August 20, 2004 3:54 pm
