15" rim
(@timo482)
im looking for a 15" x 4" steel rim - i want to build a spoke wheel to match the other two on my hd ultra / tle/u setup. right now im running a solid aluminum 15" x 3.5 wheel with a 145r15 - the tire is actually 1/4" narrower than the stock tire so i should be able to go with a 4" wide rim - possibly even a 4.5" unit with the same tire - i hope to have it all set before the tire needs replacing -then ill swap and offer the solid wheel up for sale.
i have the machine tools to drill and dimple it - just need a rim - i could even machine out the center if the rim is otherwise right.
anybody know of any source?
thanks
Posted : November 15, 2010 3:54 pm
How about a temporary spare rim off a passenger car, they are usually pretty narrow. Other place might be a old time hot rod wheel source, seems they used narrow rims on the front of many of those. Max
Posted : November 15, 2010 4:32 pm
(@timo482)
vw beetle based sand rods and kit cars used them for front wheels, also original mustangs used them for drag cars. craiger made them, centerline made them and a bunch of citroen cars used them.
ive found a few of the large bolt pattern vw ones in 15 x 4.5 ... and a few craigers 15 x 4 the vw are the closest and look to be the simplest to reman to what i need.
Posted : November 15, 2010 6:41 pm
