Peter Pan's wish list
Hello Friends,
I just sent this wish list to the local Jawa importer...
I am very interested how they will react.
Jawa 650 Blue Style specially prepared for sidecar use with the Velorex 562 sidecar which I used until now on my 2001 Jawa 350 Blue Style motor cycle.
* color blue like my 350 Jawa Blue style, year 2001.
* sidecar supports prepared on the right side for the Velorex 562 sidecar with original 16" sidecar wheel. Possibly an auxilliary sub frame is necesarry.
* pushed front swing with the pivot points mounted in needle, conical or ball bearings (no bushings!). Execution in half or 3/4 swing so that the when you break the front will not dive in or lift up.The trail should be from the beginning prepared for sidecar use (about 55-80mm) . The possibility of to change to car tires in a later moment should be taken into account. The following photografy might help for to give an idea.
(As example I remember brands like EML, Sauer, Walter, Ural)
* Stearing dampening executed in friction disk, gas presure piston or hydraulic piston version.
* Most possible the front wheel should be equiped with double disk because of the strong slopes.
* The foot's break pedal shall be prepared for to accept the original sidecar's break cable as it is in the 350 ccm Jawa.
* The gearing steps shall be specially prepared for sidecar use in heavy mountain range. Means I need a short first gear. It is necesarry to mention that Costa Rica is very hilly and ascents or slopes of over 30% are very frequent. For example the pass roads lead on only 25km from 300m to 3300m above see level.
* The secondary sprocket relation can be pretty short and a theoretical max speed of 120-130 knh is enough.
* The secondary chain shall be encaptured (enclosed) like at the 350ccm Jawa
* Speedometer shall be syncronized for the sidecar use.
* If it is possible, please install a water cooler that is extra big or double and is equiped with fan
I'd really appreciate if you prepare an explicite quotation, eventually with diferent options for the diferent topics.
Sincerely Yours
Sven Peter
- 1 Online
- 5,474 Members
