install question on...
install question on cal frindship
if you have someone sitting on the bike durning sidecar installation does it still need to lean out a little?
also does the sidecar wheel have to lean in toward the bike or should
it be level flat when empty or when I have bailest weight in it.?
Posted : May 24, 2008 2:35 am
With the bike and sidecar loaded normally, there should be enough lean-out to allow the bike to run straight on a crowned road without pulling to the right. This may entail some tweaking after road testing the rig.
The sidecar tire should be practically vertical and perpendicular to the road to wear evenly.
Posted : May 24, 2008 8:37 am
thanks im going try to get this thing on today and see how it rides
Posted : May 25, 2008 4:30 am
