Help identifying ca...
Help identifying caliper
(@bentleyssq)
  It is a Grimeca , it came off my Hannigan Astro 2+2.  No numbers that I can see.  Can’t source brake pads or rebuild kit.  Any help appreciated.  Pulled it off while checking the wheel bearing. Looked OK but I got a new one as the rig is at least 25 yrs old?  Was only 8 bucks and picture shows part number.
  Center to center on mounting holes is 95 mm or 3.710” for you machinists out there. 😁  That’s the old bearing in the photo.
Posted : April 6, 2022 8:49 am
(@bentleyssq)
  This all started as I was mounting my new sidecar tire.  Figured I better check the bearings and caliper pads while I’m disassembling stuff🤣
Posted : April 6, 2022 9:05 am
Brembo F04 long out of production. What we do when we work with these is cut the caliper mount off and weld in a new mount for the current Brembo calipers we use.
Posted : April 7, 2022 2:51 am
(@bentleyssq)
Thanks Jay.   What is a new Brembos cost for sidecar?
Posted : April 7, 2022 3:13 am
With the weld on bracket $125
Posted : April 11, 2022 6:50 am
(@bentleyssq)
Posted : April 13, 2022 5:21 am
