Harley sidecar tire...
Harley sidecar tire removal
So, I have an 03 HD with sidecar that I picked up in the fall, just before old man winter set in here. I needed a new tire for the sidecar and am trying to remove the wheel. I have a service manual and have followed the instructions. I am at the point where the wheel should be coming off and it will not budge. It rotates freely, but wont pull off the axle.? Any suggestions, am I missing something here? Guessing the wheel has not been off in the 10K miles that are on it presently. Thanks for any advice on this.
Posted : March 14, 2013 3:57 pm
 46u
(@46u)
If you did everything the manual says to do only thing I can think of is some one did not put anti seize on the axle and is stuck to the axle. See this many times on motorcycles. Many years ago I had to take a swing arm off to get the axle out.
Posted : March 14, 2013 5:19 pm
use a bigga hamma
Posted : March 15, 2013 12:45 pm
PB Blaster or Kroil Oil penetrant to loosen the grip might help.
Posted : March 15, 2013 3:26 pm
A little heat - use a propane powered torch, like the kind plumbers used to use (it's all plastic nowadays) and apply a bit of heat to it and I'll bet you it pops right off.
Posted : March 17, 2013 6:09 am
Or safer yet, a tea kettle of boiling water poured on hub will heat it up for removal, after a penetrating oil soak.
Posted : March 17, 2013 8:07 am
You do this with it over a washtub to catch the tea so you can have it to drink later.
Posted : March 17, 2013 9:59 am
 46u
(@46u)
Be careful of the sealed bearings. The bearings are not easy to replace unless you have the tool.
Posted : March 17, 2013 3:07 pm
ORRRRRRRR - Dyn-o-mite -
Posted : March 17, 2013 5:46 pm
Thanks for all the tips. I have had no success in removing the wheel and I dont have a bearing puller. I have put it all back together and decided to take it to my local shop and have them tackle it once the snow here in Pa stops...another 4-8" for today after the 4" dump this past Sat.! Where's Spring?
Posted : March 18, 2013 1:22 am
 46u
(@46u)
freaky - 3/18/2013 7:22 AM
What is snow? LOL We see it here in middle Georgia about once every 3 to 5 years other then the big snow of 73. But I would sure love to see some here in the summers as they are brutal!!!!!!!!!! HOT and HUMID!
Posted : March 18, 2013 5:09 am
(@big-al)
I had the same problem on my '04, you can take the nut loose on the back end of the axle at the frame, loosen the nut a couple of turns then use a hammer (hefty) and a protective piece of wood to loosen the axle in the frame (taper fit). Your shop can then press the axle out, be sure to use some emery cloth/tape to clean the corrosion from the axle and assemble with anti-seize.
Posted : March 25, 2013 5:25 pm
