U-joint grease fitt...
U-joint grease fitting
I was wondering if anyone know's how to grease the rear u-joint on a 2002 Ural. There is not enough clearence to get my grease gun in there.
Posted : September 22, 2009 5:10 am
Just get a needle adapter for your grease gun- It's got a zerk on one end and the other presses into the zerk you want to grease. Wish I had a photo but that's the best verbal discription I can come up with. Readily available at NAPA or most other automotive or tool outlets... Good luck.
Posted : September 22, 2009 5:16 am
Thanks, I'll check it out. I was hoping that there was a solution other than taking the U-joint apart.
Posted : September 22, 2009 5:31 pm
