Quick Disconnect fo...
Quick Disconnect for Brake Line
1 Users
I have a 1998 HD Road King with a HD Side Car attached to it. I'm wanting to know if they make some sort of a quick disconnect fitting or valve that I could attach to the brake line that would make the mounting & dismounting of the sidecar to the motorcycle a lot easier. And if such a fitting exsist, would this eliminate the need for bleeding the brake line every time I install or remove the sidecar. Thank You, Pat
Posted : October 7, 2012 12:18 pm
