progressive or linear springs
I have to upgrade my front fork springs on my 1975 CB550 in order to mount my 150lb hack. SHould I go with progressive or linear springs?
Any help would be appreciated
thank you
I would go with linear wound springs. I don't think the initial softness of a progressive spring in a telescoping fork tube for going over minor road imperfections is advantageous to a sidecar rig. I think increased linear firmness is what you would need in hot left turning or braking situation, assuming right-sidecar. A rig is much more likely to flip back over front in a left turn when under-sprung as the tub can catch the road surface.
I put progrssive springs in my old vayager and it improved ride and handeling a lot. J.R. Tex Rep
thanks.
I went with linear Race Tech springs. @ 20% suffer than stock. I'll report after I ride it a couple of times
- 7 Online
- 5,465 Members
