Harley TLE on a Road Glide
Brief intro, My wife and I live in California and ride a 2003 Road Glide and a 2001 Deuce. Have been riding for many years but new to sidecars
and have a couple of question.
1- I have an opportunity to buy a 2001 Harley TLE sidecar. I want to mount it on a 2003 RoadGlide. Will it be compatible as far as frame mounts and such going from a 2001 to a 2003?
2- Do sidecars have Titles? Do they have a seperate registration and/or tag?
Any help is appreciated.
Frank
I have not registerred or titled either of my rigs separately, and am not aware of separate vin #. The Harley sidecar might have it's own Vin, but not sure California cares.If you are new to sidecars, check out Liberty sidecars before you by Harley... they are waaaay cool. Old style Harley look, but improved suspension, etc http://www.libertysidecars.com/
Sidecar should bolt right up if you have the complete install kit. In Fl. there is no title/registration to the hack, all we have is a MSO.
Originally written by slydog on 7/8/2009 8:28 AM
and have a couple of question.1- I have an opportunity to buy a 2001 Harley TLE sidecar. I want to mount it on a 2003 RoadGlide. Will it be compatible as far as frame mounts and such going from a 2001 to a 2003?
Frank
What the other posters say is correct. I'm in California and I bought a 2007 TLE in the crate for my 2004 Ultra. It came with a factory Bill of Sale. If you dont receive the original with the sidecar, a handwritten bill of sale would be just as good. Calfornia considers a sidecar to be an accessory and not separately titled from the motorcycle, although as mentioned, it does have a VIN number. I'm looking for some change to that at some point since California is out of money. Maybe they figure it isn't worth to license sidecars based on the low volume.
The Road Glide is basically an FLH so the standard HD sidecar TLE/TLE Ultra mount kits will work. I hope you get all of that with the sidecar because a separate connection kit is around $1,200! There is the front lower mount, front upper mount, rear frame mount and rear stanchion as well as the steering damper, pre-2003 brake pedal and brake cylinder mod kit with FXR reservoir. Frequently, an owner will sell his sidecar and reatin some of the parts on the motorcycle. For example, the laydown brake on 2003 and later FL's won't clear the sidecar frame so thy use the pre-2003 upright pedal. Same with the brake master cylinder which uses a remote reservoir.
Unfortunately, HD had not changed the sidecar frame to use adjustable standoffs until around 2002 or 2003 so in order to make finite adjustments, it's necessary to remove either the front lower or rear attachment bolts to do so. Later ones are double-threaded so that the locknuts can be loosened and the standoffs turned to lengthen or shorten as required.
There is also a rollover conversion switch for the Bank Angle Sensor that changes the bike so that the engine will cut off on a complete rollover. (all hypothetical, of course, LOL) That part will not be present with a 2001 sidecar since it wasn't used before 2003. (P/N 88115-03). Depending upon the part number of your bike's TSSM, you will either be able to use one of these or you won't. The dealer generally has to toggle the TSSM for sidecar use to match this part on post 2003 bikes. I had to do that on my 2004 Ultra. 2003 was the changover year but if your bike was built early in 2002 for 2003, it may not work. All of this information is to be found in the HD Sidecar Service and Maintenance Manual. (P/N 99485-06 in my case but there is a 2009 version out by now.)
Good luck.
Here in Nevada a sidecar is considered an accessory. I think it's the same in CA. My TLE has it's own title which is often used for insurance identification purposes and retained by the bank while financed. DMV was not interested and only used the bikes VIN for registration. The advantage is that since registration is figured on the base price of the bike, the value of the new sidecar did not raise the cost of registration. Hence another advantage of a sidecar over converting to a trike (oops, did I say the T word?). I have, however seen license plates on sidecars in foreign countries.
i had a tle on a road glide - the right sidecar lower is a pain - the special cap is no longer available - can be made from a ultra one with a fine blade hack saw - ewww.
as mentioned you need the entire mount kit - used sidecars almost never have all the parts and many of them ONLY come in the 1200 bux kit.... ewwww
i ran for two years without a raked tree - then put the raked tree on - ill never own one again without it.
Originally written by timo482 on 7/28/2009 10:51 PM
I bought my right side Ultra lower on eBay. If you have the part number for the Ultra lower, both the cap and the bottom portion, you will find that they are still made since HD provides one with every TLE/Ultra sidecar.
HD is making raked trees now for the HD/Lehman Trike that they just brought out. They would probably be more expensive than the afermarket trees, although they would be steel rather than aluminum alloy.
the ultra lower has a different cap than the road glide lower
the bottom half of the part is the same for all - but the top for a ultra wont fit a road glide without some work
but it can be made to fit ok and look ok
- 5,451 Members
