Harley Oil filter relocation kit
Prev
ugly looking thing ok for a car though. It will work on the A or B motors.
Posted : March 14, 2011 2:11 am
For what's it worth-- when trying to remove a broken bolt or stud try first welding a flat washer into the stub-then weld a nut to the washer--usually works better,as you get a better shot at getting a good solid weld to the washer than you do trying to reach down into the nut. The flat washer also protects the surface of the casting,and the added heat from the two welds helps loosen the stuck bolt/stud. Give it a try sometime it does work. Hope this helps someone. It has got me out of several lousy broken#@!&%*? bolt problems over the years. HDHank
Posted : March 16, 2011 6:32 am
it is so true. Thanks for the great article becouse this information is very useful for me.
Posted : March 21, 2011 11:36 pm
Prev
- 3 Online
- 5,477 Members
Our newest member: Melvin Alexander
Latest Post: USCA National Rally 2026
