I have a 76 cb 750 hondamatic and was told this would be a good bike to mount a sidecar to. Is there any truth to this. Should i go to a manufacture and get an answer also?
Posted : August 28, 2011 5:21 am
I've seen cb750As with hacks for sale before. As long as you pick a sidecar that's appropriate for the bike weight wise and the bike is in good shape it should work.
For some reason Moto-Guzzi automatics seem to end up with sidecars on them too.
Posted : August 28, 2011 5:57 pm
We make bike specific mounts for the CB750A (the mounts are different then the CB750 mounts) they work out ok as sidecar bikes, a bit lacking on power for highway use if you have a head wind however we had a friend with a CB750A with a very heavy home made sidecar, they toured Alaska with the bike while towing a tent trailer, They traveld at a slow pace and at one point had to drop the passenger, go to the top of a long hill drop the trailer and come back for the passenger. My sister in law's first sidecar bike was a CB750A that she put a Sputnik sidecar on (bike is for sale) she ran this for years until we mounted the sidecar on a GL1000 when the CB750A started leaking oil around the head gasket. Our sidecars come with the bike specific mounts.
DMC Sidecars
Posted : August 29, 2011 6:56 am
I would think that a sidecar and trailer would be a bit much for most bikes. I would think that the automatic would be pretty good because you have a low and a high range. Just one shift either up or down.
Thanks for all your info it is helpful.
Don
Posted : August 29, 2011 7:33 am
