Adjusting Lean-Out,...
Adjusting Lean-Out, Toe-In on 85-ish EML GT?
Hi folks,
After lurking here a few months, I finally got a rig, an '85 K100RT with an EML GT sidecar. I think I'm the 5th owner; it's lived in Michigan, Minnesota and Tennessee before I took it home to SC.
I'm in the make-friends phase, and the thing handles sort of like a dump truck. So, basics first. It pulls steadily to the right, enough to require light but constant pressure to keep it straight. Research tells me that not enough toe-in can cause that. I'll check it after work today, but I have not found how to adjust it. Any ideas?
Also, I'll check lean-out tonight as well. Adjustment looks simple enough, and I know to check it with a load = my weight on the suspension, but are there any nuances or gotchas I should know about?
Also, if there's any EML-specific doc available on the Web, please send me the url. Thanks!
Posted : August 17, 2004 7:19 am
(@MikeS)
So you have the EML rig! Nashville, TN, from the IBMWR site??
I called on that rig one week after they sold it to you. I'm just entering the market for a similar rig.
Sorry I can't help you on the pull issue.
MikeS
Posted : August 26, 2004 3:26 pm
