Swing Arm or Torsion Arm California Sidecar
Looking for an OEM swing arm or torsion arm for a California Sidecar. Also can use the shock mounting bracket or bracket for the lean control motor connection. If you have any other suspension parts for a California Sidecar I would be interested in them. Mark
sadly as you know that shock bracket is not anywhere to be found unless you get lucky and find a used car that has one on it
I had to fabricate one for mine recently because it didn't have one on it when I bought it. And thanks to your picture there and the measurements you provided me I was able to fabricate one using the original shock bracket
I also had to fabricate the rear section of the frame for the sidecar top, luckily you had the other 3 parts I needed
Good luck in your search
- 10 Online
- 5,471 Members
