CSC Friendship III
Hello from a new member. Just brought home a CSC Friendship III. Looking for information on what year it was made and locating parts. I will be hooking it up to 2006 Harley Davidson Electric Glide. Is there any parts dealers available? Also looking from pictures of a Harley hook up. Thanks
Posted : December 10, 2011 6:41 pm
Should be a sticker on LH side of frame, i.e. an identiplate. They've been out of production a while, but SidecarMike has started a thread here: http://www.sidecar.com/mbbs22/forums/thread-view.asp?tid=8938&posts=90&start=1
... he's got a Friendship III. I have a Friendship II.
Posted : December 11, 2011 8:34 am
Send an email to sidecarmike at charter dot net so I have your address. I can send a zip file of mounting instructions for the FLH. Did your sidecar come off of a Harley? If it came from a Goldwing you will run into a snag. The frames are different.
Posted : December 11, 2011 1:40 pm
We can help you with mounting hardware specific to your bike, give me a call if you like.
Posted : December 12, 2011 6:07 am
I am looking for a rear CSC tail light lens. I checked 86-91 Accura but unless I missed it I did not see it. Left side red with white rectangle and amber on the right with a rounded corner. Any suggestions?
Thanks,
Mike
Posted : December 12, 2011 2:27 pm
EGRIDER - 12/12/2011 6:27 PM I am looking for a rear CSC tail light lens. I checked 86-91 Accura but unless I missed it I did not see it. Left side red with white rectangle and amber on the right with a rounded corner. Any suggestions? Thanks, Mike
Is yours the long one like this?
This is the one that is supposed to be an Acura Integra tail light. Earlier ones, I'm told are smaller than this. I have no idea what they came off of. Maybe post a photo and someone will recognize it.
Posted : December 12, 2011 2:47 pm
My tail light is about 8" wide. Left side Red with White rectangle. Right side is amber. The red side is slighty wider then the right. It Has Gemo markings on it.
Mike
Update. I found mine has a Peugeot 205 tail light. Around 1986-1991.
Posted : December 12, 2011 3:56 pm
EGRIDER - 12/10/2011 8:41 PM
The FIII was originally an EZS brought into the US in 88 or 89. Can't remember exactly although Pete at Side Effects will as he was the one that found it at a show and brought it back. I modified the original frame from metric to standard tubing sizes and put the extension on the front to make it work better on the GL1500. We put the first one on an 88.
There is no way to know what year it is. Unfortunately the serial numbers were never recorded or records kept. As you probably know CSC no longer makes or supports their sidecars. Recently they have been referring customers to DMC for assistance.
Posted : December 14, 2011 5:14 am
EGRIDER - 12/12/2011 7:56 PM My tail light is about 8" wide. Left side Red with White rectangle. Right side is amber. The red side is slighty wider then the right. It Has Gemo markings on it. Mike Update. I found mine has a Peugeot 205 tail light. Around 1986-1991.
Excellent. Any chance you can post a photo in the thread Daryl mentioned above?
Posted : December 14, 2011 3:21 pm
I will get a picture and add it to the thread.
Posted : December 15, 2011 1:18 pm
