Velorex Storage Lock
Quote from roadman48 on June 11, 2013, 10:49 amHello All,
I have an early model Velorex 562E. I need to replace the lock for the storage compartment. New ones from Velorex are aound $60. Does anyone have a less expensive alternative. Thanks for any information.
Larry
Hello All,
Larry
Quote from Hack__n on June 11, 2013, 2:11 pmIf the lock assembly is intact the cheap way out is to loosen the ass'y. and turn the whole lock 90 degrees to open and close.
Otherwise buy a new one with 2 keys for $56. plus shp'g.
Quote from Peter Pan on June 11, 2013, 9:53 pmIf not transporting any values You might use a lock of an electric panel. About 10-15$ at grainger/mc master/MSC etc.
Every electritian will be tempted to pull out his beer opener.
Chears.
Chears.
Quote from c64club on June 12, 2013, 4:20 amIf transporting some valuable goods, try a lock from electric enclosures (sold with two keys) or from mailbox. They often has the same shape (cyliner with two milled flat areas). Something like this:
Costs few bucks, has 2 keys. maybe you will need to cut some shape in tongue. Search for "enclosure lock keys" on ebay. Hundreds of them you can find for few bucks.
Quote from wvsporty on June 12, 2013, 1:08 pmI took my lock to a local locksmith shop and he sold me a new one with different latches for about $20
Quote from Guest on June 12, 2013, 7:16 pmhardware stores, or tool box replacement locks may work also,..often the actual bar that locks is simply screwed on the back, and can be changed to suit the application,..good luck, cheers crawf.
Quote from Phelonius on June 15, 2013, 3:20 pmMany hardware stores have cabinet locks that will work. Choose a solid brass one to avoid corrosion problems in wet weather.
Quote from Adam Dunn on December 27, 2021, 9:27 amI think people look for cheap alternatives not expensive and a locksmith can make it cheap.
Quote from Al Olme2 on December 27, 2021, 10:47 amAdam.
We don't mind an occasional self promotion but we really want you to make it clear that you are making a promotional post. Hiding it in the link is sneaky and not appreciated by most of the folks here. Just say that you're making a commercial post [and don't bombard us with a bunch of them]. Folks generally appreciate knowing about potential resources like yours.
Admin
Adam.
Admin
