Quote from
jaydmc on October 27, 2016, 2:45 pm
We just put the triple tree's for the T-100 back into production and got the first batch back from being anodized black today. All but two are pre sold $1000
15616 Carbonado South Prairie RD
Buckley WA 98321
Hours Monday - Thursday 6-4:30
Quote from
jaydmc on October 28, 2016, 10:39 am
Much easier steering. Also makes any front end shake you may have easier to control.
http://www.dmcsidecars.com
Buckley WA 98321
Quote from
jaydmc on October 28, 2016, 11:25 am
Yes, a leading link is a better set up however with stock sized tires on the front even if you go with a flat profile sidecar tire for more traction on the ground the larger diameter fork tubes that have been the trend for about the last 20 years seem to work just fine with just changing out the triple trees. Triple tree's keep a more or less stock look to the bike and are significantly less money. The also do not require a different front fender so you need not worry about painting a front fender as you would with a leading link.
Buckley WA 98321
Quote from
jaydmc on October 31, 2016, 11:27 am
$400 and 1/2 a day.
$400 and 1/2 a day.
Buckley WA 98321
