tires
Quote from dvjoiner on July 1, 2018, 11:26 pmhave anyone use car tire on you hack having time finding trailer tire for my hack 145/R13/75t
Quote from bentleyssq on July 2, 2018, 6:40 amI use CT on my Gwing…...Got my tires from Tires Easy on Internet for the rear and the sidecar tire.
Quote from jaydmc on July 2, 2018, 11:15 amIt is not a trailer tire in the 145 13 size. Try Coker tires. They stock them.
http://www.dmcsidecars.com
Quote from DRONE on July 12, 2018, 1:48 amdvjoiner - 7/1/2018 8:26 PM have anyone use car tire on you hack having time finding trailer tire for my hack 145/R13/75t
75T is not part of your tire's size. 75 is the load rating and T is the speed rating. So you need to look for a 145R13, or a 145SR13, though that's an alphanumeric size which isn't used much anymore. The equivalent P-Metric size is a 145/80-13. With that info, you discover that Achilles is making a modern radial in that size called the Achilles 122. It has an excellent UTQG rating (400AA), it has the same 75T load and speed rating as your old tire, only costs $35 plus shipping, and is available online [ https://www.tires-easy.com/145-80-13/achilles-tires/122/tirecode/MAF148013 ] If you don't mind paying a little more, you can order one at Walmart.com and get it shipped to your local Walmart.
