Tire change on Friendship 3 car
Quote from Txart on October 3, 2012, 10:26 amMy FS-3 tire was a Kelly 145R13 -- it was worn on the inside edge and also was cupping. Yesterday, I went to the local discount tire place and replaced the tire with a Kumho 155/80R13.
The new tire is a little taller and wider. the tread area appears smaller than the Kelly and it fits in the fender well.
My surprise was that the rig handled much much better in curves with the new sidecar tire OR at least it felt that way.
Quote from jaydmc on October 3, 2012, 10:30 amYou should check the alignment. Your tire wear shows that the alignment is off. If you need to know how to check it send me an email request to jay@dmcsidecars.com and I will send you an attachment with instructions as to how to set up a rig.
jay@dmcsidecars.com
jay@dmcsidecars.com
Quote from Txart on October 3, 2012, 11:19 amjaydmc - 10/3/2012 10:30 AM
jay@dmcsidecars.comThanks Jay --- can always use Pro help --- sent a request via e mail
jay@dmcsidecars.com
Quote from SidecarMike on October 3, 2012, 10:36 pmHow does your rear motorcycle tire wear? I've learned that if I get the alignment set to a point where the sidecar tire wears even, the rear tire wears out faster. Given the choice, I can buy 5 sidecar tires for the price of a rear bike tire and they're much easier to change.
Just my 2 cents.
Mike
Just my 2 cents.
Mike
Quote from Txart on October 3, 2012, 11:56 pmSidecarMike - 10/3/2012 10:36 PM
Just my 2 cents.
Mike
My rear tire looks fine, it has maybe 2000 miles with the sidecar.
I'm sure the tire was ok when the car was installed, otherwise the installer would (might) have said something. The changes made after the car was installed 1) a new tree from Libery 2) the bike had lowering blocks when car was installed, I removed them and made no adjustment to the car ( about 1/2" diff if that much) 3) the adjustable shock was set at lowest point when car was installed -- changed it to next higher point.
When I found the tire worn as it was, I checked toe in and it appeared ok.
Right now the rig is handling the best it has since I started this crazy sport. This being said, I do not think I will change anything -- but front tire change is coming up soon, still has the orginal Harley front tire -- any suggestions on proper tire to use.......
Just my 2 cents.
Mike
