seat belt in sidecar ??
Quote from Guest on June 7, 2013, 6:32 amDoes anyone know of where you could purchase a seat belt for a HD sidecar? Just wondering if anyone has ever done anything like this? Thinking about my youngest daughter riding in it (she's 6), as she is special needs. She does ride in it now, but tends to move around some in it now and was thinking about a seat belt for her, if it would work or not? Thanks.
Quote from Gummiente on June 7, 2013, 6:47 amI bought one from NAPA Auto Parts, a standard adjustable lap belt. It comes with large bolts and washers so you can anchor it wherever you want.
Quote from Hack__n on June 7, 2013, 11:48 amWe've installed 60" lap belts from parts stores and also harnesses with submarine strap from specialty stores for disabled passengers who do not have upper body control.
Quote from RichardM on June 7, 2013, 3:23 pmI just ordered on from Amazon. They also had the reinforcing plate to keep the bolt from pulling out.
Quote from Hack__n on June 7, 2013, 4:50 pmThe bolts will not "pull out" through the sidecar frame. The belts attach at the rear body to frame bolts.
L.
L.
Quote from wvsporty on June 7, 2013, 5:12 pmI have a seat belt in my Velorex, it was in there when I bought it. They are mounted thru to the frame and a small "roll bar" behind the seat. My now 4 year old grandson rides in there with a carseat and my homemade "redneck Haans device". check out the story of Aidens adventures at http://www.sidecar.com/mbbs22/forums/thread-view.asp?tid=11017&posts=11&start=1
Quote from wvsporty on June 7, 2013, 5:22 pmI did find out that West Virginia law requires the sidecar passenger to have a seat belt.
Quote from Guest on June 8, 2013, 9:44 amI bought a set from one of my Off Road Vehicle suppliers.
And Yes I offer them to ALL Jump Seat Passengers along with an extra Helmet(s) I have in the trunk (Youth & Adult)
Used the existing holes in Ural Side Car Tub. They lay nicely under the pull out seat until I need them.
Quote from Guest on June 14, 2013, 4:06 amActually the West Virginia law does not state seat belt at all, but actually says safety belt, instead. There is no clarification as to what a "safety belt" actually is in the law, so one could use anything from tether straps to rope and technically be meeting the intent of the law there.
Quote from Phelonius on June 14, 2013, 6:53 pmA seat belt in a sidecar would be dangerous unless the sidecar is equipped with a roll bar above the height of the passengers head.
Quote from RichardM on June 14, 2013, 7:11 pmHack'n - 6/7/2013 12:50 PM
L.
So defensive. I wasn't referring to your installation or post. Sorry if that's how it appeared...
L.
Quote from Guest on June 15, 2013, 11:17 amAnother of the many sources for seat belts is J.C. Whitney. I bought mine from them. Very good ones at a very good price. FWIW
Quote from 46u on June 16, 2013, 11:15 amPhelonius - 6/14/2013 7:53 PM
I agree and is why I do not run one.
Quote from wvsporty on June 17, 2013, 2:30 pm***Actually the West Virginia law does not state seat belt at all, but actually says safety belt, instead. There is no clarification as to what a "safety belt" actually is in the law, so one could use anything from tether straps to rope and technically be meeting the intent of the law there***
Hey Pat your right I jsut "assumed " it meant seatbelt
Quote from bikermikearchery on June 28, 2013, 12:41 pmPhelonius - 6/14/2013 5:53 PM
When I first picked up my sidecar it had seatbelts folded up under the seat. I got on this forum and mentioned the seatbelts and got this reply.
"seatbelts are for keeping your grandkids from acting like monkeys"
Shortly after I took my 5 year old grandson for his first ride. This Grandson could be the A.D.D. poster child and NEVER sits still. We had a nice ride. haveing him secured to the seat made a big difference.
Quote from Hack__n on June 28, 2013, 2:47 pmA belt or other restraint harness will keep kids and dogs from exiting the sidecar at speed in normal situations.
If the rig has turned turtle it could help or harm.Lonnie
Quote from Doug Hasert on July 6, 2013, 12:18 amSeat belt was needed so my young son would not bounce his nose on the dash during a quick stop. Used it on my granddaughters for pretty much the same reason.
Quote from Guest on July 19, 2013, 9:48 amI can't speak for a HD sidecar. My 2012 Hannigan HMS-SP2 came equipped with a lap seat belt.
Quote from Guest on July 19, 2013, 12:14 pmMy best friend just bought a Hannigan Classic Twin and it didn't come equipped with seat belt(s).
Jay S.
Okie from Muskogee
Jay S.
Okie from Muskogee
