Scissor lift
Quote from taco on June 2, 2015, 9:16 amI need a scissor 12volt lift for my sidecar seat. Can anyone help me out on a company that makes this kind of lift ?
Quote from jaydmc on June 2, 2015, 10:08 amWe have made customs ones in the past, real pain to do, one options we used one time and is the least expensive way to go is we picked up a seat designed for use in a bath tub. It came with a built in batter pack and is water proof. We then modified the unit to lift a seat. Hannigan at one time offered a seat lift for some of their sidecars, you might check with them. We have no plans to make these again.
Quote from ccridr on June 4, 2015, 12:20 amI have a Hannigan seat lift for sale. I am asking $500.00 plus shipping. I had it in hannigan sidecar for my wife before she had her hip replaced. My email is ccridr-at-wi.rr.com
Quote from Phelonius on June 5, 2015, 2:46 amYou might check with companies that sell electric wheelchairs and mobility scooters. Some of them have lifts. Maybe Pride mobility.
Quote from taco on June 6, 2015, 6:44 pmI have look into two 12V scissor jacks for about $140. So I will prefab my own lift. Thanks for all the help from you guys.
Quote from ccridr on June 7, 2015, 7:12 pmJacks are not stable enough unless you build a slide system attached to the back of the seat to keep the seat stable while going up and down. The one I have was manufactured by Hannigan.
Quote from Snakeoil on June 30, 2015, 8:18 pmWhat about the mechanism from a tractor trailer or large dump truck seat. You might find an ugly seat with a good mechanism you can retrofit to your seat bottom.
How about an old ejection seat with a short tether? 😉
regards,
Rop
regards,
Rop
Quote from claude #3563 on July 1, 2015, 7:08 amHannigan still makes the lift seat. It is for specific models but can be modified. Have seen homemade ones that use a linear actuator.
Quote from taco on July 3, 2015, 6:54 pmWell I finished my scissor lift. I used two 12volt Black Bull scissor jacks, lawn tractor battery, and a battery tender for a total of $200.00
Quote from OldSchool_IsCool on July 8, 2015, 1:07 pmNice!! Let us know how well it works. I may just have to steal your idea... er, I mean, use your build as "inspiration" 😀
Quote from taco on July 8, 2015, 1:21 pmIt works swell, I'm a little over 200lbs. and it will lift me with no problem. I do wish it was a little faster.
