Rich text editor not always available
Quote from c64club on March 28, 2013, 5:54 am"Use Rich Text Editor" appears only when posting a new thread's first post or when editing post, but not when replying in thread. Is there any way to use rich text editor when replying instead of "submit -> edit -> use rich text"?
Quote from Guest on March 28, 2013, 6:55 amFirst check your settings (upper right) to make sure rich text is your default setting. Next do not reply in the reply box at the bottom but click the reply button at the top. I always have the rich text box using this method.
Quote from c64club on March 28, 2013, 7:26 amI know. Rich Text is not my default but is available unter button called "Use rich text editor", when I create new topic or edit my posts. But don't work when replying.
Quote from SwampFox on March 28, 2013, 8:14 amc64club - 3/28/2013 7:26 AM ....Rich Text is not my default but is available unter button called "Use rich text editor", when I create new topic or edit my posts. But don't work when replying.
Be sure to "reply" by clicking the button in the upper right area of the "box" you want to reply, which, for me, brings up a new screen with a reply box with the option to "Use rich text editor" -- but I did just change my settings to default to "rich text" -- thanks to Joyce.
Quote from c64club on March 28, 2013, 8:21 amYes, this reply method also brings "Use rich text editor" button.
Probably changing default settings is the only way to get it every time I reply. Sad, because I don't like having "richer" options as default in any program/forum/system.
